Like Tree1Likes
  • 1 Post By Kdonks
Smoking
Old 08-31-2023 | 07:29 AM
Default Smoking
My Sons Hobbywing a XR8 Plus had the capacitors become un soldered which he soldered back on. After putting it back on the track and running the switch started smoking. Does anyone have any ideas what would cause this ????
Fastfred1952 is offline
Old 08-31-2023 | 08:13 AM
El_Rando's Avatar
shots in the dark here, but bridged capacitors. bad capacitors. bad switch.
El_Rando is offline
Old 08-31-2023 | 12:48 PM
The esc is most likely done. When the caps came unsoldered, that was probably due to a short or overheating. I had a switch smoke once, and after changing the switch, the esc got VERY hot VERY quickly. So, I did the replacement thing through HW. I suspect that is what you will need to do, as well.
0010 is offline
Old 08-31-2023 | 03:32 PM
Yeah, once you let the magic smoke out, it never works the same again.
glennhl likes this.
Kdonks is offline
Old 08-31-2023 | 06:41 PM
GerryH's Avatar
If the ESC got hot enough to melt the solder on the capacitors, then something was already wrong. By default the ESC has ESC thermal protection turned on, which should have shut it down if it was simply overheating. But it sounds like it developed an internal short that caused it to get that hot.
GerryH is offline
Old 09-01-2023 | 07:20 AM
Thanks guys for the bad news.
