-   -   Baattery charging error. (https://www.rctech.net/forum/radio-electronics/1112194-baattery-charging-error.html)
mv4wd 05-02-2023 12:01 AM
Originally Posted by rustyus (Post 16001107)
Anytime I had that error it usually is a loose connection somewhere.
My experience as well. That message usually comes from the charger not sensing the Lipo voltage rather than the balancing voltages. So check the main connector and any adapter you use to get to the charginh port. Use a multimeter to check if voltage is present at the charging connector before you insert it into the charger.
