Better way to charge than USB
My batteries use the JST-XHR-4P plug to connect to a USB charger. It takes over 5 hours to charge them.
Is there a faster method?
Thanks,
J.R.
Thanks,
J.R.
Technically not an Off-Road topic at all but one for here: https://www.rctech.net/forum/radio-electronics-137/
There are plenty of chargers out that will charge your batteries faster. What battery chemistry do you have? Lipo? NiMh? Lots of chargers will charge many different battery chemistries, but those chargers can be more complicated to use, so you will need to learn how to use the charger properly.
There are chargers that can plug directly into a wall socket (AC/DC) or DC only chargers that require a separate power supply - either another battery like your full size vehicle's battery or a dedicated power supply that can output 12v consistently.
From there, you will need to find the right connectors to connect the charger to your battery. So, you will have two large wires that plug into the same connector you plug into your r/c car, plus a balance board that your JST plug goes into.
Thanks for your advice. I'll switch to the Rookie section. I ordered this charger.
Amazon.com: LiPo Battery Charger Dual RC LiPo Charger AC150W DC240W 10A C240 Balance Battery Chargers Discharger for 1-6S LiPo Li-ion Life LiHV 1-15S NiCd NiMH PB Smart Battery RC Car : Toys & Games
When you get time, google, NORRCA.
