Originally Posted by Rick Draper
(Post 16037108)
I have the 458 Duo and just getting back into RC I thought I would ask for some advice.
What are the recommended charge and discharge rates for the following LiPos: 6000mah Reedy Zapper 2S 6100mah LRP graphite 2S 4250mah 4250 3S. |
I set my discharge limit to 25 amps since that's the wire soldered to my string of light bulbs.
Usually it'll be enough to warm up 2s and 1s lipos. Obviously 1s will get more amps during discharge. 4s won't get warmed up much. I generally charge at 20a. |
Originally Posted by riceball777
(Post 16035881)
I love mine. Works great. I charge lots of my batteries at 45amps no problem and can discharge my 2s at 45 amps with a resistor bank. You definitely going to want to run this with a powerful 24volt power supply. 12 volt power supply will be super limiting in terms of charging power.
https://cimg8.ibsrv.net/gimg/www.rct...a24e066b2.jpeg |
Originally Posted by dameetz
(Post 16038254)
I have the 456 model that I mainly use to charge 2 cells Lipo, may I ask whats the advantage of using 24V power supply over normal 12V?
(Post 16038254)
just remember volts times amps =watts this charger has an input limit of 50amps per 1 channels or 70amps combined for both channels. So 12 volts x 50 amps =600 watts of available power for you to use to charge your battery. With 600 watts I can only charge my 6s battery at about 23amps. But if I use a 24volt power supply like I have in my pictures now I have 1200watts of power so I can now charge my 6s lipo at the max charge rate of 45amps some 12 volt power supplies advertise some thing like 12 volts at 85 amps and 1020watts. You will never get close to 1000watts because the problem is the volts are too low. You can’t use that many input amps you need the volts to be higher. |
Thanks for the infos.
Looking around for XT90 balance boards. Can't find one to charge my 2S Rx packs for 8th scale buggy. None have the servo input lead on them all. Seems they are all just XT, EC3/5, Deans and a weird red 2 pin that wont fit my Rx pack servo lead.
New to this model currently have a 410D. I've never used XT connectors before as outputs. Can anyone link me? Greatly appreciated guys! |
Originally Posted by jkurz211
(Post 16065348)
(Post 16065348)
New to this model currently have a 410D. I've never used XT connectors before as outputs. Can anyone link me? Greatly appreciated guys! https://www.amazon.com/2Pairs-Mirtho.../dp/B07ZKKRKGF |
Originally Posted by disaster999
(Post 16065395)
Just get an adapter to change the JST connector to the servo connector
https://www.amazon.com/2Pairs-Mirtho.../dp/B07ZKKRKGF My balance boards/cables from my 410 duo do not fit this new chargers balance port. I'm needing somebody to link me to the correct balance, port cable and balance board. |
I was able to cut the ends off my charging dongles that had banana plugs and I soldered the XT90s on so I'm good there. It's just the balance, port cable and board that I'm needing.
(Post 16065520)
I think you might have misunderstood or I might have mistyped what I'm looking for.
My balance boards/cables from my 410 duo do not fit this new chargers balance port. I'm needing somebody to link me to the correct balance, port cable and balance board. There are 2 common types of balance connectors, today the JST XH is the most used. Then there are cables 3, 4, 5, 6 and 8 pole, most chargers today can handle lower pole connectors on their balance port. |
(Post 16065520)
(Post 16036450)
the alligator clips are to charge my 12 volt lead acid automotive car batteries at 45 amps. Works great for that. I also use it to charge and balance my 18650 and 21700 batteries in my power tools. Most of my rc 2s lipos are on 5mm bullets and my 4s and 6s rc lipos all use xt90.
Originally Posted by DirkW
(Post 16065528)
If I understand this right, the balance cable for your previous 4010 is probably made for balancing up to 10S and is therefore wider than the port of the 458, which only supports up to 8S. I haven't checked, but i guess it's still the same type of connector, just the smaller version. Nothing to do with XT90 or such at all. And usually you use a charging lead that converts the standard balancing connectors to a servo style connector on the battery, I've never had a balance board that included this, so pretty normal, unless you forgot to tell us everything we need.
Thx! |
| All times are GMT -7. It is currently 11:11 AM. |
