Motor recommendations >
Like Tree17Likes
Old 04-05-2023 | 11:11 AM
  #31
Originally Posted by Jblack45
Having the right setup definitely makes a big difference. The track configuration before this last one had a hairpin turn then a double jump and I noticed most other guys could clear them easily even taking the hairpin turn slow but I had to basically drive through the turn fast to have a chance to clear the double jump which resulted in me wrecking more often rather than being able to take it easy then hit the throttle.
I would gear for a little more torque. Sounds like you need less top end and a little more "outta the hole" speed.
How are your motor temps doing at the end of a heat?
Burl Swift is offline
Old 04-05-2023 | 02:12 PM
  #32
Temps are low. Around 115deg.
Jblack45 is offline
Old 04-05-2023 | 02:13 PM
  #33
Only one straight so your probably right, I need to gear for more torque
Jblack45 is offline
Old 04-05-2023 | 03:49 PM
  #34
trilerian's Avatar
Do you know the run length of the track and the time you are looking for?
trilerian is offline
Old 04-05-2023 | 03:58 PM
  #35
staiguy's Avatar
It’s definitely worth it to get a set of pinion gears. I like the ones from yeah racing. They aluminum so no steel interface, nice coating to keep noise down, and a set of 6 in a nice box. I got 3 sets to have covered from 21-38
staiguy is offline
Old 04-06-2023 | 07:19 AM
  #36
I definitely need to invest in a set of pinions. Currently I only have a 29, 30 and 31. I’ll check out the Yeah Racing brand, I’ve heard good things about some of their parts they sell
Jblack45 is offline
Old 04-24-2023 | 06:05 PM
  #37
OffRoadJunkie's Avatar
So, what do you all think about a Surpass Rocket V5R 17.5T. Are they able to compete with $100 motors?
OffRoadJunkie is offline
