Issues with Radiolink RC4GS V3 - TC4
Hey everyone,
I have an old tc4 I'm trying to get moving again. The original radio seems to be having some issues (zero communication) so I replaced it with a new Radiolink RC4GS V3. It seems like with this radio, it's also not working properly, but does somewhat communicate.
I've reset the ESC multiple times. I've re-synced the radio and the light is a solid green on the receiver. When I hit the throttle, I see the lights light up on the ESC and on the radios display, I also see the indicators going forward. When braking, the same, I see the tekin g10 responding as the lights light up and I also see it on the radios screen. Similarly, when I steer to the left, on the radios screen, it's showing a left turn indicator (while the wheels are going right), and vice versa.
Anyone have any ideas? The radio is brand new.
- When I have it connected, the steering works but it's reverse (when turning left, the wheels go right and vice versa)
- The Throttle does nothing at all, except the front servo twitches a bit when hitting the throttle.
did you read manual? switch steering direction. recalibrate esc to new radio.
Yup, actually reversed the steering to solve that problem after I posted this. But the throttle issue remained. What oddly ended up fixing is was when I ran the built in ESC test on the Tekin G10. Once the testing concluded, it started working. Strange one!
That speed control is about 25 years old right? Does that work right. Also read the manual on the speed control - just like any newer speed control there is a calibration between the radio and speed control that you need to follow - - see step 5
https://www.teamtekin.com/manuals/G10manu.pdf
After I did this test, everything started working immediately after. Maybe bc after the test is done "Activating the self-test mode also resets all the mode selection and other set-up parameters to factory default values". So maybe this reset on the ESC did something. All is good now, she's alive after 15 yrs
