Install battery weight plates >
Like Tree3Likes
  • 1 Post By tbrymer
  • 1 Post By sosidge
  • 1 Post By gwhiz
Old 07-23-2022 | 06:21 AM
mac853's Avatar
Default Install battery weight plates
Hi, In fact I never use before weight plates under battery.
I just want to know if the weight plates would stick on chassis or in the battery.
If anyone want share also about what kind of tape and how to stick with it, please?
Best regards
mac853 is offline
Old 07-23-2022 | 07:22 AM
tbrymer's Avatar
I've always stuck them to the bottom of the batter with double-sided very thing pieces of tape.
mac853 likes this.
tbrymer is offline
Old 07-23-2022 | 07:54 AM
sosidge's Avatar
I've always struck then to the chassis (no need to add weight to all your batteries, just to the car). The ones I've bought in the past have always come with thin double sided tape, and that's what I'd use, no need for thick tape which wastes space.
mac853 likes this.
sosidge is offline
Old 07-23-2022 | 08:59 AM
gwhiz's Avatar
3M 5925 ( .6mm thick) https://www.3m.com/3M/en_US/p/d/b40072038/
3M 5908 ( .25mm thick) https://www.3m.com/3M/en_US/p/d/b40065685/
mac853 likes this.
gwhiz is offline
Old 07-23-2022 | 09:20 AM
mac853's Avatar
I believe the batteries must be attached 1 by 1 with plates, of course is really expensive in case you have 3 or 4 packs, the another problem is low of plates you can find in stock.
Anyway, thanks!
Originally Posted by gwhiz
wow, these 3M are really something, I never saw these on the mall, maybe I need to check this in online, thanks!
mac853 is offline
Old 07-23-2022 | 01:28 PM
HarryLeach's Avatar
Tesa 4965 is my go to double sided tape for really thin attachment to a chassis. Works well for plates, ESCs, transponders, tungsten cube weights for ballast, whatever. It holds well, best if everything is degreased and given a bit of full-bond time before stressed, but it'll work if you're in a hurry as well.
Sam Isaacs put me on to the stuff, and it's pretty much replaced all my other "servo tape" options used previously.
HarryLeach is offline
Old 07-25-2022 | 08:57 AM
What’s the purpose of a battery weight plate?
RacingRookie27 is offline
Old 07-25-2022 | 10:00 AM
mrreet2001's Avatar
R/C Tech Elite Member
To add weight below the battery.
mrreet2001 is offline
