-   -   1S discharger availability? (https://www.rctech.net/forum/radio-electronics/1095568-1s-discharger-availability.html)
Sandfreak 02-02-2022 10:36 PM
Lots of stand alone dischargers available for 2S but I can't seem to find any for 1S.
Roelof 02-03-2022 01:59 AM
With some electroncs easy to make
Sandfreak 02-12-2022 01:11 PM
So is this redneck set up LOL. But in my internet searching have never seen a DIY 1-S discharger with adjustable discharge rate and voltage cutoff. If you can share a link I'd appreciate it.
https://cimg9.ibsrv.net/gimg/www.rct...b499ae2499.jpg
Roelof 02-12-2022 02:06 PM
Easy to design. I would go for an OPAMP to do a voltage comparisation with a reference voltage and a simple flipflop circuit as start/stop. Controling a relay and some resistors wits some switches to select the discharge rate.
My home build 2S discharger is basically doing the same but using a LiPo alarm as low voltage detection.
https://www.rctech.net/forum/radio-e...ischarger.html
Sandfreak 02-12-2022 02:12 PM
Thanks for the link. I'll check it out after my race tonight.
ramman347 08-26-2022 06:52 AM
I just run my cells down on vehicle. Only takes a min or two at full speed. I have made a light discharger too. If one small bulb doesnt discharche fast enough add another in parallel. If batt gets warm lose one bulb.
disaster999 08-28-2022 08:51 PM
Sometimes that is not feasible due to various of reasons...track closed, started pouring outside, its getting late etc. At that point a discharger is needed to bring the battery down to storage voltages.
