-   -   Balancing charge lead help! (https://www.rctech.net/forum/radio-electronics/1094636-balancing-charge-lead-help.html)
mocrawlin 01-13-2022 05:19 PM
I have a track power VR-1 charger. Ought from friend, didn’t have any balance boards or leads. I have leads made up for 2S balance charging from my Orion charger and hitech that I no longer have, but I believe the pin orientation is different maybe? Cause with no battery connected and the balance plug in its reading almost 6 volts on cell one.
here is a pic of port. Should the negative wire be far left, and then cell 1 far right and then cell 2 the next and so on and so on?
https://cimg9.ibsrv.net/gimg/www.rct...59a2b72ec.jpeg
mocrawlin 01-13-2022 05:44 PM
I figured it out. Far right is negative, then each cell after that. That’s how it’s working right now anyway. LoL
big ted 01-14-2022 08:28 AM
This is correct. Pins 1-6 are in order of increasing voltage. Ie:
pin 1 = 0V (or negative)
Pin 2 = +1s vs pin 1,
Pin 3 = +1s vs pin 2,
Pin 4 = +1s vs pin 3
Etc
Obviously, for a 2s pack you only use 3 pins.
the rc guy 01-14-2022 12:12 PM
pin 1 neg-
pin 2 + and neg
pin3 +- so on t
pin 6 that's +
any
JST-XH board with 6 cell will do
