5Likes
Battery Discharge current for Storage
Hello,
I have a fully charged 6000mah 7.6V LiPo, that I am using my Sky RC D100 changer to put in to Storage. What current should I select for storage discharge ?
Alistair
Alistair
What you will want to consider is rebound voltage as it relates to current and it depends on your discharger and how it stops the current flow.
For instance, on my 406duo, I can discharge at 40amps in storage mode and it will sit about 3.87 throughout the week with a cutoff of 3.85
If I use my sky RC 35 amp discharger, I'll get significantly more rebound in the voltage because it cuts off as soon as it touches 3.85. On the sky, if I am going to storage, I do 10 amps to slows the voltage crash down a bit.
