How to prevent cogging without buying new motor >
Like Tree5Likes
Old 08-19-2021 | 06:22 PM
  #31
Adding to this I found in some motor setup combos that I have had required the throttle position to literally almost be a touch ‘on’ in forward position, and tinkering around with brake settings and what not
Juglenaut is offline
Old 08-19-2021 | 08:58 PM
  #32
yea, skewed magnets are the standard outside rc. I have not seen it applied in rc motors however. But if we are wishing for better tech a sinusoidal waveform and field oriented control is the standard for cogging control outside rc.
I have also seen poles separated longitudinally on the rotor rather than side by side which does offer some control advantages.
I do know of experimentation with magnetic material that isn’t north or south but a continuous blend from north to south and back again. this means no big changes in fields that come from stacking north and south side by side.
Bry195 is offline
Old 08-20-2021 | 01:19 PM
  #33
It's an expensive hobby. Best to read up on stuff first.
mrreet2001 and gigaplex like this.
Skynet5 is offline
Old 08-20-2021 | 01:31 PM
  #34
Dave_S's Avatar
Hobbywing uses a magnet setup like that with the Axe FOC system.
Dave_S is offline
Old 08-26-2021 | 07:07 PM
  #35
I know the axe is FOC but is it running skewed magnet stacks? Hobbywing tech is legit. I believe they would be first to the punch if they aren’t already.
Bry195 is offline
Old 08-26-2021 | 09:25 PM
  #36
Dave_S's Avatar
They run this, they call it staggered poles. You can see magnets are offset a bit
Dave_S is offline
