-   -   Battery, motor and esc questions (https://www.rctech.net/forum/radio-electronics/1085301-battery-motor-esc-questions.html)
Jocomotive 05-22-2021 08:59 AM
I have a 60a esc and a 4300kv motor which I currently run on a 2s lipo with a 30c discharge rate and a 4000mAh size. I want to know however if I would be able to run a 3s lipo with this setup.
The motor specifications are 4300kv with a 3.5T rating with a max of 75amps with a resistance of 0.0075 ohms
The esc specifications are 60amp esc from surpass hobby.
I would like to hear if anyone knows if I can run a 3s lipo with this setup and if anyone can suggest any cheap but good options.
billdelong 05-23-2021 04:32 AM
Generally NO, your combo is best suited for 2S... while it may work on 3S, your gearing options may be severely limited due to temps, more info here:If you are wanting to run 3S, then I would recommend a motor in the 3200KV range, I would also invest in a 120A ESC as well, those 60A ESC's won't last very long on 3S if you over task them.
the rc guy 05-23-2021 05:32 AM
No 4300kv is to many kv to run with any long term success. id look into a 3600kv or under 3300 kv is ok
