Need a good power switch
So last year I put away my hobao hyper SS nitro cause I thought I had radio issues. Well put new batteries in both buggy and tx and on the bench all seemed find. So took it out today and about 5 min in it ran off and I had no control. Switched it on and off a few times and it had power again. So this leads me to think the switch is bad. So what's a good switch, been out of the nitro game for years.
Suspended
The safest switch is a blind plug. Take an extension, cut the negative wire, put a female connector of your choice (there's some JR connectors that come with a tab if you want extra security) into that place, the end going to your battery as pin 1, the other as pin 2 (or vice versa). Then get a matching male connector and just short the aforementioned pins on that. Need to turn it on? Put in the plug! Need to turn it off? Pull it out!
I also like electronic switches. Many companies offer them, hobbyking has them for cheap under the TrackStar brand, SkyRC has one, Futaba has one, there's a Protek one as well iirc.
