-   -   Avid iCharger cables (https://www.rctech.net/forum/radio-electronics/1079618-avid-icharger-cables.html)
Silverbullet555 01-23-2021 02:16 PM
Back when I bought my ICharger I also bought a couple Avid charging cables. Finally went to put them to use and they are stupid tight going into the charger. Is this the norm or did I perhaps get an out of spec set?
I did email them, but thought I would check here too.
billdelong 01-24-2021 05:31 AM
I have not owned the AVID cables, but I would like to think that a tight fit is a good thing, also want to double check that you're using the 4mm plug into the charger and not the 4mm to 5mm step down end?
Silverbullet555 01-24-2021 06:24 AM
Tight to a point is good. Tight to binding not so much. And yes, I'm using the 4mm plug into the charger vs the 4/5 battery end.
Thanks for taking the time to respond though. When the track reopens in the next couple of weeks, I will swap cables with a couple people there and see if the fit is significantly different.
