Caring for LiHV is a bit different than standard LiPo
#31
Interesting thread. how would a 7,4V charge impact on capacity?
Lets say we have 6100 mAh 7,6 HV lipo. Guess the capacity would decrease if charged as 7,4V LiPo?
Is there any way to recalculate the mAh so it's corresponding with 7,4V?
Example 6100mAh@7,6V or 5800mAh@7,4V
#32
First off, don’t assume that higher voltage means more speed - if your cells don’t have a low Internal Resistance, all bets are off. It’s all about Ohm’s Law… The owner of the hobby shop I used to buy from back in the day used to say, “At your level of competition, batteries win the race - don’t spend your money anywhere else if you don’t have the juice to drive it.” Believe me, back in the days of matched and graded sub-C cell packs, better batteries quickly got me up from the C mains to the top of the B’s statewide, and winning series’ at my local track. Anyway, IMHO, it’s just a matter of time before the sanctioning bodies just allow charging to 4.35. I think the biggest driver is that as cells deteriorate and people end up buying new cells (LiHV), there will be less worry and pushback about people having to buy new packs.
I wouldn’t go around saying that LiHV’s are just glorified LiPo’s though. By classifying them as LiHV’s, the companies are basically assuring you that you can charge it to 4.35/cell SAFELY (as safe as LiPo’s cells can be, anyway). I know that I wouldn’t feel comfortable charging a standard LiPo cell to 4.35V. Care wise, I would just charge them to 4.20 (if competing under current sanctioning rules, special allowances excepted, of course), and store them at 3.8V, or whatever voltage works for you (I know people have differing opinions on that)… but I predict that one day soon, ROAR and the other sanctioning bodies will raise the ceiling to 4.35V when they think it will have minimum impact on the user base.
#33
Plus not all new packs are sold as LiHV. There's still a lot of high end batteries that advertise standard LiPo voltages.
#35
#36
#38
As I saw many rules in Europe, US or even in Japan are tighly restricted of batteries just charge until 8.4, if goes into 8.44 would be considered overcharge then would be hardly penalized.
But i saw in somewhere of Southeast Asia still allow charge until 8.44.
Then I verified Lipo would swelling in case charge it 8.44.
Could someone tell in case the rules is allowed 8.44 would have advantage for LIHV than LIPO?
Could someone tell me LIHV could be charge with 2C?
Anyone would fully charge LIHV until 8.7 then discharge it until 8.4 before race for better perform?
#39
LiHV won't benefit from 8.44V any more than a LiPo would.
LiHV and LiPo can both be charged with 2C (assuming the rules allow).
Charging a LiHV to 8.7V then discharging to 8.4V won't perform any better than just charging to 8.4V directly, other than marginal internal heating which could lower the IR. But you can do that without overcharging, people already cycle the packs.
#40
Charging a regular LiPo to 8.44 won't cause swelling by itself, that's within normal voltage tolerances.
#41
#42
For indoor black carpet the trend is ULCG batteries. After checking 8 band new batteries, most of them LIHV, from different manufacturers the big majority of them have ok to terrible IR. You have to blast them with high current for them to have average IR.
#43
ULCG batteries tend to have higher IR in general - smaller cells with less surface area.
#45
41Likes
