M12S RS help
Old 10-01-2020 | 04:51 AM
Default M12S RS help
Can someone explain how to use the mixing function of this radio?
i have an electric Losi 5b I’m trying to have the manual brakes work with the esc . I guess it would be the mixing function but I’m lost on using this radio. I want both to work on the trigger and set end points for the servo only to move when I hit the brakes.
thanks you
albert
mustangman50 is offline
Old 10-02-2020 | 07:02 AM
In the system menu there is an option called ‘type’ that lets you pick a car type that some of the basic channel settings.
If I understand what you need to do, maybe car type III would work? You can then adjust the brake endpoints independently as needed.
mushroomed is offline
Old 10-02-2020 | 08:08 AM
If you do use this car type III, you can then go in to the 'racing' menu and adjust the br2 mix in the 'br-mix' section of the menu.
Old 10-02-2020 | 02:23 PM
I will try to play around with this on the weekend.
thank you I’ll see which type works
