Like Tree1Likes
M17 Screen
Old 09-29-2020 | 07:13 PM
  #16
Originally Posted by Krazykurt88
does anyone know where or if its possible to get a new top screen for the m17? Mine has some weird like little bubbles on it would like to replace it. There's no issues with it just my ocd with screens
Loli have same mine i posted in M17 thread drop small glue then it works fine no more bubbles
raved007 is offline
Old 09-29-2020 | 08:24 PM
  #17
would it take care of the little like pin holes in it
I cant really answer that but maybe you can. it shaves microscopic layers off with every pass. can you polish it long enough to round the pinholes out so they arent an issue or even longer so that the rounded out pinholes are just as flat as the rest of the plastic? it will be perfect if you put the time in.
its the same thing as most of the high quality headlight repair kits. you can use a power tool. However you have to minimize heat from friction otherwise you wont get the clarity you want. all plastic polish works this way. Ive personally never used a headlight restore kit that has you apply a clear coat or filler that creates the clarity that you get from polishing the plastic and then sealing the plastic. filling the holes and building up the surface to polish it back down works and is quicker but the potential for clarity is higher if you polish first.
most plastics will allow you to use sand paper. this is how i restored headlights and fish tanks that are full in the past. you rip the surface down with something that doesnt leave grooves until you are at the same level as the scratches or pits. then you use progressively higher grit wet dry paper to remove the scratches from the previous grit of paper. you can skip as many grits as you want. just remember it takes twice as long to sand if you skip stages of the grit progression.
Bry195 is offline
Old 09-30-2020 | 03:07 PM
  #18
Zerodefect's Avatar
On my older radio, the screen was part of the motherboard. Too much of a pita to change out.
Zerodefect is offline
Old 09-30-2020 | 05:18 PM
  #19
Krazykurt88's Avatar
yeah I've looked everywhere for a replacement even on sanwa website and I dont see it anywhere..I dont trust myself to take it apart so im gonna try the buffing it out method and see what happens
Krazykurt88 is offline
Old 10-14-2020 | 10:26 PM
  #20
SuperFastSnail's Avatar
Thanks for sharing that with us. I'll be sure to get/buy a screen protector for it when I get my M17 in a month or so, waiting on Black Friday deal at Amain.
SuperFastSnail is offline
Old 10-22-2020 | 11:56 PM
  #21
Hello Dear, As I see the condition of your screen, it's better to replace the screen.
Mammoser_Solder is offline
Old 03-23-2021 | 09:29 PM
  #22
Any updates on your screen. Mine is in the same condition? I got a really good deal on mine aswell and was thinking about a screen replacement
Ducatiman2020 is offline
