ProTek Servo Disassembly
Hello, I have a Protek 160SS High Speed servo that feels a little funky around center. I would like to disassemble it to check the servo gears. I have removed the top and bottom 4 screws but am unable to remove the top to view the servo gears. Is there a trick? I don't want to force it if there is an easier way to remove it.
It is possible that us just a gear then perhaps. I have not had this model servo apart but sometimes there is 2 hidden screws under the board but I don’t believe so. Sometimes the upper case sticks on the output shaft. With a small flat blade screwdriver you can easily try to separate the cases and get a little wiggle and determine if it is just stuck or still retained.
Ordered replacement sets August 24th "Just in case". Disappeared off tracking August 29th. Emailed Customer support on Friday. It usually takes them 4-5 days to get back to me.
Thanks in advance!
Hi there Bsthetech ! Any luck? I removed 8 screws and tried to pry it apart with no success... Are there hidden screws that I can't seem to find?
Thanks in advance!
Thanks in advance!
Edit...so no stripped gears in my servo (surprised!). It was the bearing that was shot!!!
