Motor repair... Grinding itself to a paste?
Hello,
I have a castle motor where the shaft broke. Ordered a replacement. Took the motor apart, pressed out the broken shaft, which took a lot of effort, then pressed in a replacement from banggood but it seemed much easier, I can pull it out by hand.
Seemed to have one spacer by the end with the wires. Put it back together and gently ran, seemed like a fine dust coming out and vibrated a bit. Thought the shaft was not positioned in the spacer, reassembled and less vibration but still a lot of this mystery brown dust.
Help?
Help?
I don't think it's dirt... I blew it out, soaked all the bearings, before putting it back together and I still got all that. Unless the sand is hidden somewhere within, but it wasn't that dirty when I first took it apart. I swear it's from something wearing down it seems.
Also with the replacement shaft being a bit loose, should I be adding some ca glue before reinserting?
First off how did you break the shaft? Secondly how much did the new one cost? Did you take the bearing out that was pressed in? If so castle will tell you that you will almost never get it in straight. That could be your problem. If I were you, I would pack it up and just send it to castle for repair. More often than not they will just junk it and sell you a new one at %50 off.
Hi RubberMatt,
The shaft broke near the pinion while bashing. The replacement shafts were off ebay - about 10 bucks. I left the original pressed in bearings as is. I ended up adding epoxy to the shaft and then inserting it, which took away the play. Once the complete shaft / rotor unit is back inside the can, there is some play of the whole shaft/rotor side to side, but it runs much more smooth, though I still get some of that brown grit coming out. I still don't know what it is - it isn't dirt.
I've never seen a motor do this. Whatever you have done, the motor is garbage now. That dust is probably a mix of winding and rotor material. If you put a new rotor in that motor now you are probably looking at a smoke show soon thereafter (which would likely cook the esc too). You would have needed to balance the rotor after replacing the shaft in addition to gluing the new shaft to the magnet with the appropriate adhesive.
Junk it
In picture number 1 is that the current setup? If so its bad. Like really bad. The rotor should have a shaft on both ends. The ends should be supported by a bearing. With the shims in place to help center the rotor and take out play.
It should look like that. Did you try to press out the middle shift out of it?
Yah, I pressed the middle shaft out and replaced with a new one. But it was spaced correctly with the spacers. I had no idea you couldn't replace the shaft, thought the old castle repair kits had this. Well... I guess it's junk!
It not junk. Send it to castle for them to fix. It will cost half of a new one. Plus I think you can upgrade. Like go to a different kv if you want.
Did you have a shaft on both ends? Because picture 1 does not show a shaft.
I think the castle rotors have the fiberglass wrap dont they? it may be pieces of that rubbing on a rusty stator.
