Toro TS150 Issues.
Old 04-19-2020 | 06:37 PM
Default Toro TS150 Issues.
So I got a Shining Star Slash LCG in a lot of stuff I bought.
I put it together using parts I had laying around. The ESC is a Toro TS150 competition and I just can't get it to work right.
I started with a new Flash Racing 4800 KV 2 pole motor, and it would barely run at all, cogging like crazy with or without the sensor. I geared it down a bit, no difference.
I switched to a Tekin Pro4 4600 kv 4pole. It works better, but from dead stop, and sometimes low speed and accelerating hard, cogging again. I resoldered all the connections, changed the timing setting, boost settings, everything I can think of and I can't make it work right.
Anyone have any experience with these ESC's?
MaxxAction is offline
Old 04-19-2020 | 08:07 PM
Geezatec's Avatar
Read the Toro manual on calibrating ESC & Motor, especially when changing motor. Calibrating Neutral, Full Throttle and Braking.
Geezatec is offline
