Ko Propo EX-10 Helios outdated?
Hey fellas. I have a guy offering to sell me an EX-10 Helios with a 2.4 GHz module for $50. It's in good shape but I don't know much about it. I know it was a good radio in it's day but it's been out for a while and I don't know if it's still decent by today's standards? If anyone has any thoughts or anything they think I should know I would greatly appreciate it. Thanks.
To me that radio was nice a little heavy on long mains but still decent, so my .progression with radios over the years was a.m. radios of the past then the Ko and then a spektrum dx3s all the receivers worked since the Ko had the spektrum module in it, and went to dx4s just because of Rx's and them a buddy said try airtronics mt4, and I bounced off walls and corners due to lack of delay in the radio, so what is your current radio compared to this Ko radio as never liked having to read the first 80 pages of the manual before you could turn it on and like I said it was heavy, 8 aa batteries and tons of options and overwhelming at times. So 50 bucks would be a cheap price for it as 225 new with out rx and then 50 bucks for a radio bag and 125 for module, hope it helps
Over time, potentiometers will go out, it took roughly 3 years of racing 2 days each week between 2-3 classes before I wore out my steering potentiometer on my current radio... it was as easy as buying a new steering drop down to replace for me, I would check to see how easy it will be to get parts for the EX-10 before getting it, could potentially be more trouble than it's worth.
The asked about EX 10 is not the radio you wore out the pots with the new electronics makers are fare more inferior than those parts from the EX I raced with this radio with both FM and 2 different 2.4 modules till the 2nd module failed then I jumped in to my specktrum night- mare dx 3 r pro.( lose of signal..crazy short rang issue would lose signal in a indoor 40x40 carpet track and a few more failures) its totally to the Ex 10 to compare your mid range radio thats your quote...
I think I'll chance it and hope for the best with the potentiometer. Worst case I can probably most of my money back selling the module, receiver and case if the radio doesn't work out.
Just dont agree with you at all on the EX 10 Helious… I know welding robots from the 80s that have dozen of pots in them that have been running 20 hours a day with thousands of uses a hour that are still running today and haven't needed new pots..
Radio Modules ? Kopropo America
If you are going to be driving by yourself then that is probably going to be just fine, but if you will be club racing with other radios present then I would stay away from the DSSS protocol, more info here
Which surface radio system is the best?
The newer DSMR variant is significantly better, but I still experienced range issues on a large 1/8 track when I attempted to race with DSMR once, regardless I don't think the DSSS module will support DSMR anyway, which will not be compatible with the same DSMR receivers you already own
Here are the specs from Spektrum, they show DSM support only:
https://www.spektrumrc.com/Products/...ProdId=SPM1003
I'll never forget racing with a guy that was nicknamed Steve "TheGlitch" who used one of these DSM Modules, he would often be in the lead during a race only to get hit with glitches toward the end of a race and would lose several positions, the guy refused to replace his DSM equipment, really sad
7Likes
