Blew up ESC - recommendations >
Like Tree5Likes
  • 3 Post By SteveM
  • 1 Post By tbrymer
  • 1 Post By norlin
Old 01-26-2020 | 07:25 AM
norlin's Avatar
Default Blew up ESC - recommendations
I haven't used my TC5 in years. It has a Novak GTB ESC and Novak 10.5T brushless motor running on a 2S battery.
Unfortunately, fool that I am, I bought a new battery, charged it, and promptly went and plugged it in backwards. Fried my ESC but hoping my other parts are ok (receiver, motor).
Does anyone have any recommendations on a modern ESC I can replace mine with as I'm completely out of the loop these days.
Appreciate it!
norlin is offline
Old 01-26-2020 | 07:43 AM
Hobbywing XR10 Justock is about the best value today. This is a blinky only ESC just so you know. They make other models with adjustable settings if you need boost, etc.
norlin, billdelong and dman18t like this.
SteveM is offline
Old 01-26-2020 | 07:44 AM
norlin's Avatar
Thanks for the fast response! I will look into it, I had no starting point so this gives me a place to begin.
Thanks again!
norlin is offline
Old 01-26-2020 | 07:50 AM
There are so many good ESC's out there and it all depends on your budget and intended use. I've used the Hobbyking Turnigy 80A brushless ESC in my 2wd Slash when I raced Mudboss and it was perfect as well. I've also used the SkyRC speed controls and they were fine as well. I find the Hobbywing ESC's to be the gold standard though.
SteveM is offline
tbrymer's Avatar
The new R1 super stock is amazing! It just came out a few weeks ago and I've been using it with great success. It has every configuration option you'd ever need.
https://r1wurks.com/collections/elec...-pre-order-now
norlin likes this.
tbrymer is offline
Old 01-26-2020 | 08:41 AM
Looks to be a nice price on a used Hobbywing XR10 here. NOT MINE
Onroad Electronics
SteveM is offline
Old 01-26-2020 | 10:14 AM
norlin's Avatar
Excellent, I ended up picking up a new JUSTOCK from Hobbywing Will see how it works and hope I didn't fry anything else on my car.
SteveM likes this.
norlin is offline
Old 01-29-2020 | 09:08 PM
TurnNBurn's Avatar
FYI, if I’m not mistaken there’s at least one model in the HW XR10 line that has some reverse polarity protection. It will blow the capacitor stack, but at least replacing that is much cheaper than replacing the entire ESC!
TurnNBurn is offline
Old 01-30-2020 | 12:46 AM
gigaplex's Avatar
That's the new XR10 Pro G2. They also have optional capacitors that won't blow either.
gigaplex is offline
