Motor timing question >
Like Tree1Likes
  • 1 Post By Bry195
Old 12-29-2019 | 07:10 AM
Default Motor timing question
So my motor won’t turn all the way to zero degrees but it will go past the highest point I e looked but I can’t seem to figure out if it’s just the way it’s installed ?
rrb1399 is offline
Old 12-29-2019 | 08:11 PM
GerryH's Avatar
Probably it's the way it's made. What motor is it? There's little to no reason to run 0 degrees of timing on the motor. You usually want 40-50 degrees of advance. But every motor is different.
GerryH is offline
Old 12-30-2019 | 04:34 AM
Suspended
You don’t want that much timing on a mod motor 10-30 degrees typically
Losiracer12 is offline
Old 12-30-2019 | 05:23 AM
It’s a 17.5 r1 works motor
rrb1399 is offline
Old 12-30-2019 | 08:54 PM
around 40 degrees it will be efficient if you gear it for low rpm. Somewhere between 40 and 50 you will get the most power under the curve and retain some efficiency. Closer to 50 you will extent the rpm out but lose low and mid efficiency.
GerryH likes this.
Bry195 is offline
Old 12-31-2019 | 11:18 AM
Thank you this carpet track I’ll be running is tight small with short straights so I want to gear it to be able to clear jumps that are after fast turns what’s a good starting point 27/72?
rrb1399 is offline
