-   -   Motor always faster in reverse? (https://www.rctech.net/forum/radio-electronics/1053592-motor-always-faster-reverse.html)
lifeofbrian 11-09-2019 11:52 AM
I have a Hobbywing QuicRun 120a ESC a connected to a Turnigy Trackstar 7.5t Sensored motor and no matter what I do (apart from switch the motor wires and go sensorless) the motor always goes much faster in reverse.
I have calibrated the Throttle range as per the manual in every way I can think of, with the TX channel 2 reversed and normal, calibrated the throttle reverse instead of forward. It always ends up with the reverse much faster?
My TX is a Flysky FS-GT3B.
billdelong 11-10-2019 09:06 AM
check your wiring so that A-B-C wires correspond between the ESC and Motor
GerryH 11-10-2019 07:25 PM
Except with a sensored motor, if the wires are not correct, the motor shouldn't even spin. Or at least it would be coggy.
When you are going forward on the transmitter, is the motor spinning counter clockwise? It sounds like you have forward and reverse, reversed.
Does the ESC have any lights on it at neutral?
Bry195 11-10-2019 08:31 PM
I dont know if it applies because i run a different system but i can set the end point on throttle to 110 percent and it give me more speed. Doesn’t hurt to try it.
mushroomed 11-12-2019 03:15 PM
If the motor has adjustable timing on the can, make sure it isn't accidentally set in the negative direction, as this could also cause this behaviour.
the_real_hova 11-16-2019 07:07 PM
Not mentioned yet - but run through your ESC radio calibration again. The ESC may not know where the radio's endpoints are and is not seeing "full throttle".
gigaplex 11-17-2019 02:30 AM
It was mentioned in the original post.
the rc guy 11-17-2019 06:55 AM
anyway to adjust ccw or cw of motor I think that is the only fix op has at this point..Id do that then rev will be fwd..https://www.google.com/url?sa=t&rct=...wCKgGG73PwkKyc
gigaplex 11-22-2019 03:33 PM
Originally Posted by clarc (Post 15549923)
Someone might have made a mistake and limit the forward power in ESC, hard to judge without programming card, easy to check is swapping the outside wires around and see
As has already been mentioned, you can't swap the wires around on a sensored motor.
