Best fans that hold up well? >
Like Tree1Likes
Old 05-28-2019 | 03:10 PM
tibbs's Avatar
Default Best fans that hold up well?
just curious what fans people are having best luck with ? Seems like any plastic fan falls apart very quickly?
tibbs is offline
Old 05-28-2019 | 03:25 PM
socalcloin's Avatar
I have Yeah Racing 30mm Aluminum Tornado Fans on my cars.. beat them up pretty good and no issues.
socalcloin is offline
Old 05-28-2019 | 04:21 PM
plastic fans suck and i use to break them all the time. I now run the yeah racing full aluminum Tornado Fans. They work great and they wont break on you like the plastic case fans.
riceball777 is offline
Old 05-28-2019 | 06:39 PM
I_NeedBigDrink's Avatar
R/C Tech Elite Member
I broke two plastic fans the same day i bought them. Like the others said, the YR aluminum tornado is great. Been running it for a few months with zero problems. I wonder if it's the aluminum case or maybe stronger/thicker plastic on the blades, but it definitely works!
I_NeedBigDrink is offline
Old 05-28-2019 | 07:07 PM
Di_spencer's Avatar
I've had pretty good luck with the 15mm R1 fans and they have reverse polarity protection which is nice
Di_spencer is offline
Old 05-28-2019 | 08:05 PM
Another voucher for the Yeah Racing 30mm aluminum fan. I've heard some people complain of the noise and wear them out on high voltage by soldering the wires directly to the battery posts, but in my experience using 7.4v bec, they last a very long time and move a good amount of air. Just make sure to secure the wires leaving the fan case as they can easily come unsoldered, a small dab of shoe goe will prevent the wires from pulling off and you'll have yourself a very dependable fan.
trf211 is offline
Old 05-28-2019 | 08:34 PM
i have used hot racing fans and had the fan pop out of the base, same issue with the traxxas vxl fans.
Ive had great luck with my yeah racing plastic fans.
What is everybody running that caused your fans to break?
enare is offline
Old 05-28-2019 | 11:23 PM
1/8 IC Fan's Avatar
On my XR8 ESCs i run the Hobbystar Aluminum fan, holds up great in 1/8 Buggy.
https://www.rcjuice.com/motor-esc/mo...30mm-gold.html
raved007 likes this.
1/8 IC Fan is offline
Old 05-29-2019 | 05:35 AM
+1
I used to go through plastic fans about once every couple of months, been using the same Aluminum Case Tornado fan for over a year now, worth every penny!
billdelong is offline
Old 05-29-2019 | 09:43 AM
RC*PHREAK's Avatar
for sure the aluminum case fans hold up better. i've been liking the surpass (the OEM of the hobbystar above).
the number one failure i've had with fans is the wires coming off the fan board. metal case won't prevent that. i shoe goo the wires to the case to prevent them from getting pulled out and that has increased the life of every fan i've done it on.
RC*PHREAK is offline
Old 05-29-2019 | 10:02 AM
On the Tornado fan, the solder tabs are exposed of the motor/fan so you can re-solder the wires and shorten wiring very easily
Old 05-29-2019 | 10:04 AM
RC*PHREAK's Avatar
good to know. i'd rather not have to so for me, the shoe goo works well.
Old 05-29-2019 | 09:27 PM
Sir 51D3WAYS's Avatar
I've had problems with breaking blades after landing insane jumps....
Didn't realise aluminium fans were a thing.
Sir 51D3WAYS is offline
Old 05-30-2019 | 12:44 AM
RC*PHREAK's Avatar
Just the case is aluminum. Blades are still plastic and can still break.
Old 06-23-2019 | 06:30 PM
I used the aluminum case yeah racing fans I went through 3 of them in a practice day at the track. 1 broke after landing a hard jump, so I doubled up the tape on the bottom to give it more cushion. That didn’t help it broke on the same jump 15 second into a lap. Then the last one broke a couple laps later. Now I’m using the muchmore 30mm turbo fan and it seems to be holding up well. I have about 5 weeks right now on the muchmore.
Rook45 is offline
