FlySky Noble NB4
#1171
Nice review! I can't say I've experienced the steering delay on either my NB4 or Pro but I maybe I haven't payed much attention. Reviews like this may some bother people (perhaps the fanbois) but getting this out there is how positive change happens. I do wish you lived closer to me, I'd lend you my Pro so you could race with it and see how that'd compare. One thing that Flysky claimed was that one could transfer their NB4 data onto the Pro but that didn't work for me, perhaps it wasn't ready when I tried? I plan on trying my Pro in '1 way mode' to see if there is any noticeable difference. I always use 2 way mode to monitor the lipos in my nitros.
#1172
What steps did he take to get it back up and running? I'm having the same issue.
#1173
Hi all,
New here and have been reading this very long thread, also searching for error and datum etc. I have a new NB4 with 2.0.85 firmware, hardware 1.2 I am trying to save my models before I upgrade the firmware, but using Assistant 1 and 3 (2 is just in Chinese and seems unresponsive) I get the error below. I am hoping to get the models saved before updating firmware... any ideas?
Thanks in advance.
EDIT: I read possibly I need Assistant V1.1 Does anyone know how I can get this file? I can't find it anywhere.
TIPS:
"The return datum from TX have not received, waiting for timeout!"
John
Thanks in advance.
TIPS:
John
#1174
Hi all,
Thanks in advance.
TIPS:
John
Thanks in advance.
TIPS:
John
#1175
Thanks,
the Assistant software sees and names my controller as NB4 in both V1 and V3. I've tried hooking it up power on and off, both before I ran the software and after and it does not seem to matter... same error. I have read I must have V1.1 Assistant... but can't find it anywhere. Maybe someone can email it to me or upload it somewhere, seems odd they have left me as a new owner without any recourse.
Thanks for you help again,
John
John
#1176
Hello
Does anyone know about NB4 strange beeping sound on startup? Device emits weird repetitive sound & doesn't boot up at all. Top led doesn't have light.
If it's used without bottom battery base - no more sound and doesn't work either.
PowerBank seems to be okay, it charges my phone. As a guess, maybe I have to replace 18650 battery?
Unfortunately, I cannot share YouTube video link so check attachment (zip file with short video).
Thanks in advance.
Thanks in advance.
#1177
Hi,
I've never heard that noise. I heard there is a hidden button, I think on the left side of the grip, Higher up under the display and it's small and not sure what it does but someone used it to "reset" theirs. I can't find the link, but here is another bit of info... a link to YT vid with "reset" info. Good luck, let us know if you find out how to fix this please. Oh...I can't post links so add this to Youtube.. /watch?v=RR-fdMGLpoI
or search
Regards,
John
or search
Flysky NB4 hidden service menu and TX power settings
in youtubeRegards,
John
#1181
You may want to try one of the steering springs but at the end of the day, I'd still like more tension. As of right now, there are no aftermarket options for steering springs unfortunately unless you come up with your own custom solution. I did not attempt mounting two springs at the same time (if it's even possible) but if one could, chances are the plastic spring hook mount might not take the extra load. Flysky needs to fix these little issues to as the Pro is simply an amazing radio.
#1182
Wow, I missed this. You know, I saw your latest video where you unboxed your new Losi 8 nitro. All I can say is, enjoy the journey! There is nothing like a nitro, both good and bad.
Anyway, I'd recommend you run at least in "2 channel" 2 way mode on the Losi. For me on my Pro, it's VERY noticeable the speed difference coming from 4 channel mode.
Also, in your NB4 review, you mentioned that you had issues when attempting "1 way" (fastest) mode. When I initially tried 1 way mode, I thought it wasn't working; The reason I thought this was because I was expecting a "bind complete" confirmation and never got it. I think many fail to realize that in 1 way mode, there is ZERO data/telemetry feedback so the radio will just show the binding bars even when bound. As soon as the RX blinks solid, just unplug the bind plug and you're good to go. Not saying this was your particular issue, just throwing it out there. 2 channel-2 way mode is fast but 1 way mode felt a bit moar faster to me personally.
#1184
So, im an OG rc guy and used Airtronics up until they started the changes to the roaming channels.. i dropped rc racing for awhile and now returing. Im interested in this radio as it fits my budget. My question is does the NB4 use any servo? i cant find anything about servo compatibility?
#1185
700Likes
