Changing KV rating and max amp >
Like Tree2Likes
  • 1 Post By Davidka
  • 1 Post By LzREngineering
Old 01-25-2019 | 03:10 PM
advfuel's Avatar
Default Changing KV rating and max amp
I am currently using the Hobbywing 21.5T V10 G3 Xerun motor.
The event rules state 2400Kv, max 1.5amps
Now on the motor checker, my motor is producing 2434kv @ 3.6amps
The G3 comes standard with a 12.5mm rotor
Question, with out purchasing a load of different rotors, what do i need to bring the amp draw down to 1.5 amps ?
Cheers
advfuel is offline
Old 01-25-2019 | 05:05 PM
Davidka's Avatar
If that motor has adjustable timing, try dialing it back a couple of degrees. Shouldn't take much.
billdelong likes this.
Davidka is offline
Old 01-25-2019 | 07:16 PM
advfuel's Avatar
Yes It has timing adjustment....but to get 1.5amps the timing is set to the bottom of the scale and its only performing at 2050KV.
Im thinking there must be a way to get a higher KV with the same amp draw. I seen a video with a muchmore guy, but doesn't really make sense
advfuel is offline
Old 01-26-2019 | 07:10 AM
You can try adjusting the shims, or gap between the rotor and the sensor board, typically you want all 3 phases of the timing check to be within 1° of each other and this gives you optimal efficiency which will also increase your RPM and reduces amp draw, more info on an example here:
REVIEW: NOVAK NX4-3900KV 4-Pole 540 Motor
billdelong is offline
Old 01-27-2019 | 09:04 AM
LzREngineering's Avatar
Try a weaker rotor (probably sold as a high rpm version) to get more Kv per amp
advfuel likes this.
LzREngineering is offline
