Battery Charging Question... >
Old 12-17-2018 | 08:26 AM
  #16
Davidka's Avatar
Another thing to consider is that charge rate and charge time are not a linear relationship. The Lipo CC-CV charge algorithm tapers current through the last 15-20% of the charge so that that last part can take a while.
For a charger, look ultrapower. I believe they make chargers for several more mainstream brands (the UP120AC looks a great deal like one of Reedy's chargers). Now that you know the wattage you are looking for, you might find what you need there for much less $$ than some of the bigger-name brands. I have a UP100AC Duo. It's tiny, charges two 2s batteries at a time, as fast as I need and runs on AC power. I only wish discharge power was greater, because it takes a long time to storage-discharge at only 1.3a. Bigger chargers should be more powerful in this way.
Davidka is offline
Old 12-17-2018 | 08:58 AM
  #17
Originally Posted by Evoking1230
Thank you for the explanation. I understand that much. Most likely will keep it at 1C but if at the track I'll bump it up to 1.5C to shorten charge time.
I wouldn't worry about charging at 1c to preserve battery life. ebuggy and etruggy already put a lot of stress on a 4s pack. In addition, you are taking life away from the pack if you are consistently pushing it to LVC.
With current racing batteries, charging at 3C+ should be no issue.
071crazy is offline
Old 12-17-2018 | 10:36 AM
  #18
Originally Posted by lowspark
If you are going to race, chances are you will never have to recharge a battery from zero so your charge times will be a lot less.
Example... I use 2s 8000ma batteries in my SCT... 10 min race I still have approx 25% of the battery left.
I use a Protek charger that is 80w and I charge at 8a. It takes about 30 minutes to charge back to full capacity.
LVC is set at 3.2
Note that I never run my batteries down to low volt cut-off... I use a timer set to 8 minutes when practicing.
this is true. My son wants an eBuggy as well and Im sure he will take that down to LVC on the regular, which is why I was thinking of the iCharger.
Evoking1230 is offline
Old 12-17-2018 | 10:39 AM
  #19
Thank you for the recommendation, I'm looking into them now :-D
Old 12-17-2018 | 10:40 AM
  #20
even if there's a big warning sticker that says "DO NOT CHARGE PAST 1.5C"?
Old 12-17-2018 | 11:50 AM
  #21
And you believe charging at 1c will have a significant effect on the life of your packs.
071crazy is offline
Old 12-17-2018 | 12:23 PM
  #22
I'm new to electric so I'm only following the manufacturers instructions. If I can charge higher than I'll try it.
Old 12-17-2018 | 12:24 PM
  #23
Really liking the UP120AC. Question for you, the charge leads that go into the unit are they 4mm banana plugs? Some pics they look bigger.
Thanks!
