Brakes?
Old 09-07-2018 | 08:55 AM
Bikerbob's Avatar
Default Brakes?
Ok, so last night I have got the gearing now set for the track, I have my straight line speed good. I am carrying big speed into corners, but I need brakes at the end of the straight, and I cannot seem to get enough.
Running xcar60amp esc. Punch and top end are great. Brake max is set to 100% drag is @ 20% initial force is at drag brake. Nothing more I can do with the esc I think.
Controller is a MARS - I have max brake, punch, and curve.
Other thing I find is going from full on to full brake in the trigger seems like a mile. What if I setup the controller end points again with the ESC and only go about 1/2 way into brake?
Be Honest, not just upsell the cheap guy.. would a higher AMP esc make a difference in braking?
James
Bikerbob is offline
Old 09-07-2018 | 04:19 PM
Assuming this is for one of your 21.5 TC's, then you shouldn't have to brake. Unless there is a really sharp turn at the end of the straight, then just let off and let the drag do it's work and then hit the throttle as soon as you can.
rcbuggy88 is offline
