Help with Maclan ESC and Motor >
Old 02-03-2018 | 11:43 PM
Default Help with Maclan ESC and Motor
Hey guys,
Got a problem with my ESC and/or motor. I'm using a Maclam MMAX Pico and a 13.5t MRR Team Edition Ver2 motor. They are fairly new and have been running fine for my last few races, but has now developed a problem when I use full throttle. It sort of like stutters for a bit before it launches. If I ease the throttle on it's okay. I've taken a video which will hopefully show what I'm talking about.
+ https://youtu.be/PBOPW_jCaKg" title="View this video at YouTube in a new window or tab" target="_blank">YouTube Video
https://youtu.be/PBOPW_jCaKg"> https://youtu.be/PBOPW_jCaKg" /> ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
It doesn't do it with my other Maclan ESC and motor. I've reset this ESC, I've changed the slipper and gearing, changed the sensor cable, and the ESC reciever cable. Nothing seems to fix it. Could the capacitor module be dead and need replacing?
stuffandthat is offline
Old 02-03-2018 | 11:52 PM
Have you tried swapping the motor out with a working motor to try and localize the issue? If the problem goes away, there may be an issue with the motor, if the problem persist, there may be an issue with the speedo. Now vise versa, put the motor in your other car and see if its indeed the motors thats the issue. When were the units purchased? you may have to exercise the warranty and proceed here:
Hobby Authority
PS. And post here: Maclan Racing Products Discussion next time. There are company reps that follow that thread.
trigger is offline
Old 02-03-2018 | 11:54 PM
They were purchased about 2 months ago. I haven't tested the motor separately as I don't have the means to unsolder / resolder to another ESC.
