Sticky protek servo
Old 01-15-2018 | 08:49 AM
Default Sticky protek servo
I recently brought a protek 100ss servo from my lhs to run in my slash 2wd racer. I don’t run a servo saver and have aluminum bell cranks, steering knuckles and servo horn. The servo is sticking to the right endpoint. When I turn it to the right the servo just stays there like there’s a blockage in the steering rack. When the servo started doing this I disconnected it from the steering rack and moved it by hand and the steering rack was smooth and free. I am at a loss to what was causing this especially because the servo is less then a month old.
Jigsaw49 is offline
Old 01-15-2018 | 10:12 PM
It sounds like you may have stripped the servo, especially given there is no servo saver and stiff aluminium bellcranks.
mushroomed is offline
Old 01-16-2018 | 04:41 PM
disaster999's Avatar
Regional Moderator
Is this happening when you're turning the wheel by hand or with the radio?
disaster999 is offline
Old 01-17-2018 | 11:59 PM
rustyus's Avatar
If you open it up and find no stripped gears, then contact ProTek, and hope they don't tell you that you abused the servo.
rustyus is offline
