My servo is sticking?
Hi I'm honestly not quite sure what to call my issue. But this just happened. I was driving and then my servo just started making a noise like really loud screech only when I turn to the right. Also it's like getting stuck in the right position, only when I lock out though. If I do gradual right turn its okay, but if I lock it out it makes the loud noise and sticks. Is this a broken gear set in my servo or is it something in the linkages?
Yea it's not a linkage issue, the server just gets really stuck and like then it snaps when you get it out of the lock, so I guess its broken... RIP. Broke during the easiest session ever.
I've had luck taking a stripped gear and rotating it 180° to get more life out of the gear, though I would probably order a replacement gear set anyway if/once you confirm you've got a stripped gear. Maybe loosen your servo saver a pinch?
