2012 Nitro Challenge
#136
#137
#138
gotta move this one to the racing forum.......
#145
Frank, the new truggy impacts have been run on the current layout; although "he" said they were good they still had too much bite and were a lil prone to hooking. The new truggy grids were great! Per the driver who has them already.
Our current layout is blownout!! So impacts on a fresh smooth surface should be really good. I ran them up until the track got rough.
#147
I've been switching back and forth between impacts and gridirons during the day on our current layout. There are major ruts but when the track is dry I still like Impacts better. When it's watered you can run slicks and hook up. Small pins are for sure the more popular choice though, and I am not smooth on the throttle and I like my car to launch when I punch it.
#148
Ha ha frank .
Any tire will hook up at this track. As James said when the track is new impacts are a great choice , although depending on your setup they could cause a little push in corners because they do have more bite then gridirons . I personally will use impacts for practice and maybe for Rd 1 qual in truggy but after that it will be all grid irons
#149
Has anyone tried the Blockades or the Tazers out there?
#150
I have ran blockades. They are ok. Pretty much what everyone is saying. Its a really high bite surface when watered. The blockade is good when dry or would probably be when the track is new and smooth. I would have hole shots too though. You can also get away with a harder compound. If you had something in m2 or medium I bet it would be just fine. Personally feel soft grids is the best option though.
