The Us Indoor Offroad Champs hosted at Motoroma
#63
SPEC SCT CLASS RULES
Body
Must be a Short Course Truck body. No Beetles.
Chassis
Traxxas Slash, Associated SC10, Losi Strike and HPI Blitz. No modifications may be made to the chassis system. Vehicle must be raced in its stock form. No aftermarket or Hop up replacement drive components may be installed. The chassis must be stock, no aftermarket. All kits must use their supplied components - no mixing brands. You may use anything that came in the OEM box.
Suspension
Both the front & the rear suspension systems must remain in stock form. Original parts only.
Steering
No modifications may be made to the steering system. Original Kit parts only. All kits must use their supplied components - no mixing brands.
Electronics
Original Kit electronics Speed Control & Servo only. All kits must use their supplied electronics - no mixing brands.
Motor
All kit's must run the motor that was supplied in the kit.
Battery
This class is limited to any 6 cell sub c Nimh or 2S 7.4 Volt Lipo battery pack.
Tires
Box Stock. No mixing Brands. Slash must run the Slash tires, Sc10 must run the SC10 tires and so on. Must be 3.0” inside bead diameter x 2.2″ outside bead diameter.
MORE To come
Body
Chassis
Suspension
Steering
Electronics
Motor
Battery
Tires
MORE To come
#64
Radio and rx may be changed also shock oil and gearing may be changed no ball diffs, may change gear diff fluid/grease
#65
At hobbyrama I did not see anyone checking any of the Spec trucks. I would like to see all of the spec trucks checked after a race to make sure everyone is playing nice. I know that there are a lot of of guys running RPM stuff out there. I take pride in the fact that my Slash is bone kit stock and still goes well.
#66
#67
I saw in a previous post there is a motor limit for the Mod 2WD SCT of 13.5 or 19T is that still the rule or will Mod simply be mod just curious. I want to have the correct motor for the race. Also when is the deadline to sign up before you get nailed with the late fee. Thanks.
#69
TW u need to wheel a buggy 2 or 4, not a truck
R
R
#70
Here are the 4wd SCT rules from the first page in this thread:
"Provisional Shortcourse 4w
We know there will be 2 trucks avalable at this time the Jammin and the new Traxxas this will be a full mod class,ANY THING GOES."
That leads me to beleieve we can run the buggy tires.
Tony,
I'll be there if you need any help. This is Jason Sneed from RC Pro in Gloucester. jasonsneed AT gmail DOT com
See you guys in February.
#71
ROAR rules apply for everything but SCT. SCT rules were posted in this thread.
#73
any clue on dirt since we're in a new venue for electric? i'm buying tires, and they are not cheap and i'm not alone. more info please. lotta folks had a choice of crcrc or motorama and quite a few chose crcrc b/c they knew what tires to use. c'mon !!!
R
R
#74
will be getting 5 loads of pond clay should be a high bit track but you know how a temporary racing surface can be
#75
