Quebec onroad Nationals 4th edition
Following the huge success last year with more than 170 entries, making it the 2nd biggest race in Canada East Coast... Circuit Téléguidé St-Hyacinthe comes back with its 4th edition of the Quebec onroad Nationals...
Be ready for great RC fun, high grip black carpet and poutine! Quebec Onroad Nationals - 4th Edition April 27, 28, and 29, 2018 Classes Sedan 21.5T Stock o Any 1/10 scale, 190mm, 4wd touring car o Any ROAR approved 21.5T brushless motor o Any ESC blinky mode ROAR approved o Weight Minimum 1,350grs o Minimum height 5mm o Tires: Jaco Blue byo - Available at the track o 2S 7.4v ROAR approved Maximum 8.44v Sedan 17.5T SuperStock o Any 1/10 scale, 190mm, 4wd touring car o Any ROAR approved 17.5T brushless motor o Any ESC blinky mode ROAR approved o Weight Minimum 1,350grs o Minimum height 5mm o Tires: Jaco Blue byo - Available at the track o 2S 7.4v ROAR approved Maximum 8.44v Sedan Mod o Any 1/10 scale, 190mm, 4wd touring car o Any brushless motor (540 size can) o Any ESC – ROAR approved o Weight Minimum 1,350grs o Minimum height 5mm o Tires: Jaco Blue byo - Available at the track o 2S 7.4v ROAR approved Maximum 8.44v Pancar 17.5T Stock o Any ROAR approved 17.5T brushless motor o Any ESC blinky mode ROAR approved o Weight Minimum 730grs o Minimum height 3mm o Spec tires BSR or CRC only - available at the track o 1S 3.7v ROAR approved Maximum 4.22v Pancar Mod o Any brushless motor (540 size can) o Any ESC blinky mode ROAR approved o Weight Minimum 730grs o Minimum height 3mm o tires: open o 1S 3.7v ROAR approved Maximum 4.22v USGT o Any 1/10 scale, 190mm, 4wd or FWD touring car o Any ROAR approved 21.5T brushless motor o Any ESC blinky mode ROAR approved o Weight Minimum 1,380grs (4WD) o Weight Minimum 1,200grs (FWD) o Tire = GRC124 (Pre-mounted), GRC125 (tires only), Ride 24025 o Minimum height 5mm o 2S 7.4v ROAR approved Maximum 8.44v F1 o Any 190mm, 2wd rear wheel drive Formula 1 Chassis. 270mm wheelbase max o Any ROAR approved 25.5T brushless motor o Any ESC blinky mode ROAR approved o Weight Minimum 1,050grs o Any commercially available F1-specific rubber tire may be used, any tire inserts can be used o Minimum height 3mm o 2S 7.4v ROAR approved Maximum 8.44v Tamiya Truck (Fun class) o Box stock class - Built as per manual o Ball Bearing only approved hop-ups o Tires permitted are the part numbers included with Tamiya kits #58632 and #58642 o Hard case LiPo batteries that fit the chassis, as designed, without modifying the battery or chassis. o Maximum Capacity of LiPo batteries shall be no greater than 6000mAh o Maximum LiPo battery voltage when tested is 8.44v o Any 6 cell Sub-C NiMh battery that fits the chassis, as designed, without modifying the battery or chassis. o The only motor permitted is RS-540 Torque-Tuned Motor o Stock Gear ratio only o The only ESC permitted is the TBLE-02S included in kit o ESC battery connector may be changed to fit the battery used in the chassis. o Motor bullet connectors must remain as they came in the kit. Tamiya Mini o Legal chassis platforms: M03, M05, M05 V2, M06 and M07 o Silver can motor o Any ESC ROAR approved o Weight Minimum 1,300grs o Tamiya internal gears only. Aftermarket idler and spur gears are not legal o Tamiya Mini tires (55mm and 60mm) o Bodies available for use with M03, M05, M06 and M07 are legal and may be used on any chassis platform. (No sedan bodies allowed) o 2S 7.4v ROAR approved Maximum 8.44v NOTE: Min 10 entries to run a class Entry Fee and registration: https://www.rcsignup.com/events/disp...nt.cfm?ID=6193 - 1st Class= $40, 2nd Class =$20 and 3rd Class = $15 - VIP member 1st Class= $20, 2nd Class = $10 and 3rd = $5 - Entry Deadline April 25th, 2018 - Entry Fees thru PayPal: [email protected] Track Race will be held at Circuit Téléguidé St-Hyacinthe Facility 15075 Ave Guy St-Hyacinthe, QC Permitted traction compound = SXT 3.0 Pit tables, chairs, & power sources will be provided LiPo battery sacks for charging are recommended http:// SPONSORS: Circuit Téléguidé St-Hyacinthe 450-278-0215 |
