Go Back  R/C Tech Forums > General Forums > Painting, Designs, Graphics and Photography
USGT Body Pics and Paint Discussion. >
Like Tree155Likes
Old 02-02-2019, 12:40 PM
  #571
How long does it take to do these bodies!
grumpyduck is offline
Old 02-04-2019, 10:05 AM
  #572
vivo quevas's Avatar
Trader Rating: 19 (100%+)
Not as long as you would think. Paint is quick masking takes hours.
egalsim likes this.
vivo quevas is offline
Old 02-05-2019, 02:45 PM
  #573
flyingm's Avatar
Haven't seen any USGT photos lately. Probably won't get to race till May, but decided to paint a new body while it's snowing out, C5 Corvette.... At least I'll be ready.....
flyingm is offline
Old 02-06-2019, 06:05 AM
  #574
JC3
JC3's Avatar
Yeah, that's the body I should have gotten instead of the 200mm #311.
JC3 is offline
Old 04-09-2019, 03:39 PM
  #575
Originally Posted by Josh-n-ya
To add to the Gulf theme.
This is one of my favorites...
eR1c likes this.
FlatSix914 is offline
Old 05-01-2019, 07:15 AM
  #576
Why am I so graphically challenged. Does anyone have a good place to buy mask or does everyone use the liquid? I never liked it
Azsmartbet is offline
Old 05-01-2019, 07:32 AM
  #577
Originally Posted by The One They Call Dirty
Finally got around to mounting up my body for USGT. Diggity Designs slaying it as always with the paint!
Anyone know how to get this texture on the paint?
Old 05-01-2019, 08:00 AM
  #578
Years ago...many years...when I was airbrushing T-shirts, I'd frequently airbrush other things (tumblers, coffee mugs, leather goods, etc) for people. As much as I disliked using liquid mask, it does have its uses. There are times when, due to the physical shape of whatever you're painting, it can be difficult (or even impossible) to apply a sheet-based mask. A perfect example would be a sharply-curved concave or convex corner. It's situations like that where a liquid mask is your only real possibility. Like I said, I dislike liquid mask...but, there are times when it's your only realistic option to get done whatever you're wanting to accomplish.
Panther6834 is offline
Old 05-08-2019, 10:17 PM
  #579
R/C Tech Elite Member
First time painting a body. Based off the Red Bull Holden Car. to many hours using a vinyl cutter. Only stickers used are the Cadillac stickers.
egalsim, angrymelon, eR1c and 4 others like this.
Psychotikcow is offline
Old 08-29-2019, 12:27 PM
  #580
TheRulesLawyer's Avatar
That's all paint? Dear god I can't even imagine how much time you spent masking.
MonkeyCmonkeyDo likes this.
TheRulesLawyer is offline
Old 10-05-2019, 01:14 PM
  #581
JC3
JC3's Avatar
eR1c and MonkeyCmonkeyDo like this.
JC3 is offline
Old 12-28-2019, 09:33 AM
  #582
Knockoffracer's Avatar
Lots of decals. And a heat gun. Lol
Knockoffracer is offline
Old 01-09-2020, 11:08 PM
  #583
Finished a couple more bodies that can be used for USGT.
tomthegeek likes this.
Old 01-10-2020, 01:17 PM
  #584
This is a tricky question, because to some, the painting IS the hobby.
lets see... a few days deciding on design. Printing out a black and white sketch of the car, and using colored pencils to try a few different themes and then sleep on it.
Then trying to find the paint color (and testing of color blends), and see if any store has in stock, figure another couple of days until pieces arrive.
With spray cans:
Wash the body - 1 min
let it dry - depends on how dry the air is after wiping down. Can be 5 min, can be 30.
start to mask windows - about 10 min.
If you are doing just 1 color, shoot the body lightly for a thin barely there coat. 1 min.
Then wait 10 min and spray the color a little thicker. Wait 15 min (longer if humid, shorter if you have a hair dryer.
Repeat 2 more times. then back in white or black depending on the finish you want.
With a hair dryer you can single coat of paint a car in about 15 min. With air drying it takes a hair over an hour.
Peel off window mask, peel off outer protective layer. 3 min.
cut out wheels and trim - 5 min
add decals - 20-60 min depending on how many.
If you're a pro, you can do the cutting and peeling in seconds. Also you can speed up the dry time with tools. But it's harder than it looks.
For a regular Joe? It takes a couple of nights. The painting is usually a longer time commitment than the chassis.
Now if you are adding design, you have to work with liquid mask or tape. With tape, you have to let paint fully dry so it doesn't lift between masks when removing or moving the mask around, and each color requires the multi-step paint between layers (more complex with candy's and transparent paints). So, if you just want to air dry, it can take a couple of days of just paint time assuming you can only dedicate an hour or so each evening, or figure out how you can squeeze in 90 seconds of painting with lots of drying time throughout your day.
With an airbrush or hair dryer/heat gun everything is accelerated because the drying time is so much faster. If you check youtube you can see super complex designs done in only a day. With liquid mask you shift the mask time to up front. With paper mask, the initial mask is easy, but it gets intricate in between.
I'm amazed at stuff like this:
and down the rabbit hole you go...
Seth
Knockoffracer likes this.
sethwas is offline
Old 01-29-2020, 11:29 AM
  #585
Just finished my PF C7R for USGT. Based on the Larbre Competition C7R scheme.
egalsim, Buckaroo, jph98 and 1 others like this.
Jeff H is offline
