Liquid mask?
Liquid mask?
Is the hobby grade stuff like Fasmask a latex based solution?
Is it the same solution that can be found at a paint shop or is the hobby grade solution slightly different?
Thanks very much! Good to know.
Will wait till I can get my hands on some Fasmask then
I have had very good luck using A product called Sign Strip made by Spraylat. It is an industrial spray mask used in the sign painting business. It is similar to Bob Dively except it is much thicker and is only available in 1 gal. or larger quantities. At $45 a gal. it is actually cheaper than Bob Dively.
I buy my supplies from Coast A/B and they are $75 a gallon.
Im still using Dively for the time being.
I have used both and they both have good and bad. Bob Dively's seems to stick better and spray better but it takes more coats. Fasmask takes one to two less coats for the same coverage thou cleaning the gun after fasmask take more time. To me they both seem to cut and peal about the same. For me the bottom line is I can get fasmask at wholesale and have to pay retail for Bob Dively's so I normaly use faskmask.
