My big air compressor
well i want to get a passche double action airbrush. and i have a craftsman 15 gal air compressor. i was wondering if i could use it for air brushing? its got a dual regulator on it so i can adjust the output pressure... any help, Thanks
Re: My big air compressor
Yes you can use it I use mine with up to 50lbs. of presure,but get an Iwata air brush they are far superior! Try e/bay they have them cheap!
thanks you guys.... if there any fittings im going to have to buy? and if so, what size? or dose that depend on what brush i get?
The hose that comes with the Paasche is a direct hookup to a 1/4 NPT female so as long as you have 1/4 NPT male out fitting then it just screws on and off you go.
I use a Paasche braided hose for my Iwata (good quality and cheaper) so all I had to do is get a Paasche hose to Iwata adapter which are readily available.
I would also recommend an inline filter/water trap. Just an ounce of prevention.
Happy AB hunting!
Happy AB hunting!
