My Airbrush Experimental Projects
#16
Lol. I know I know. I need to just get one done. But I want to make sure it'll be perfect so one more test run on transparency paper and to make sure everything will be nice and clean looking before I shoot my shells!! I know how to eliminate my mistakes. I just need to turn up the patience meter along with some trial and error!
#21
To be honest I'm not sure what a good cheap cutter would be. I've only dealt with Graphtec, Summa, and Roland and some other printers at the sign shop I managed at.. If I could lead you guys to one I would. But I just haven't looked into them before. If I come across a good deal on a small cutter I will keep you guys in mind.
#22
I'm kinda gettin good at this for only owning my Talon for about a month now. So here's one more teaser before I shoot my first shell in the next day or two!! . Side note. If you don't have a Iwata pistol grip filter. I'd suggest getting one. Man are they nice...
#24
Thanks Monkey! I'm still learning what transparent colors to use with each other though. I was hoping the inside edges were gunna going to be a deeper red then how it came out. But I'm still pleased with it! Its so cool how you can change the shade to your liking!!
#26
For the carbon fiber, all I did was shoot the pearl blue first and left the pattern piece for the carbon fiber in the same place on the substrate and then sprayed opaque white wave / streaks. I then removed the pattern piece and then I backed it with pearl purple spraying over the entire carbon fiber area. So where I sprayed the opaque white streaks, the carbon is more vibrant and will stick out more giving the flowing effect or rolling effect. Hope this helps ya!
#27
wow for only doing this for a month I think it is incredible even for someone that has been doing it for awhile. The thing that makes bodies stand out IMO is the shading and blending and making certain things pop out and others stay back to where when you really look at it you can see it and go wow look at the detail, like shaded skulls or whatever just in small amounts. I can't wait to see a body you paint. Very nice.
#28
With being in the Sign business all these years that has developed my understanding of all colors and what works to give you the most contrast.. So I defiantly know how to make them pop and stand out!
I think I'm going to use that tribal flame graphic with the checkers on the sides. So I'm currently designing the hood and roof. So if all goes well I should have pics posted of my first painted shell in the next day or two!
