Spraying Liquid mask, thin it?
Old 07-18-2011, 02:49 AM
Default Spraying Liquid mask, thin it?
I have a cheap Harbor freight spray gun just sitting around. Was wondering if you need to thin out the LM before spray and if so with what?
skye b. is offline
Old 07-18-2011, 04:57 PM
mx51's Avatar
I use a cheap Harbor Freight gun to spray my mask and i do thin it a bit with water.I just think it's a little to thick to spray straight out of the bottle.
mx51 is offline
Old 07-19-2011, 04:02 AM
Thanks MX. How many coats do you prefer?
skye b. is offline
Old 07-19-2011, 05:48 AM
Bfutura15's Avatar
I spray 3-4 wet coats
Bfutura15 is offline
Old 07-19-2011, 06:56 AM
I use a cheap external mix Hobbico to spray. I thin with water as little as possible til it sprays even and lay down 3-4 coats as mentioned above. If too thin it doesn't cover think enough and end up with really thin patches that are a pain to peel
vash42 is offline
Old 07-19-2011, 10:26 AM
I just sprayed LM for the first time last night. I used a cheap siphon feed external mix AB. I didn't feel the need to thin it. It sprayed pretty good at 45ish PSI. I was using Fasmask and a Badger 250.
Jamie James is offline
Old 07-19-2011, 05:40 PM
mx51's Avatar
I spray 3 pretty heavy coats using a hairdryer after each coat on the last coat i set it aside and dry for 24 hours
mx51 is offline
Old 07-19-2011, 09:53 PM
Just sprayed for the first time. Wow!! What a difference! Definitelly will not be going back to the brush!
skye b. is offline
Old 08-06-2011, 06:31 AM
Sk3tch's Avatar
I'm usually pretty stubborn when it comes to techniques I don't usually use...but I have 6 bodies that need to be prepped and I really didn't feel like doing my usual 5 coats of hand brushing the mask....SO I got a HF $15 detail spray gun and sprayed the mask that way.
I used 50 PSI with the mask thinned about 20-25% 3 coats is equal to my 5 brushed.
I swear I saved a TON of time (and it looks smoother). I also saw somewhere somebody made a "cure" box. That saved some time as well as opposed to me rotating the bodies in front of a space heater.
I will never brush liquid mask on again.
Sk3tch is offline
Old 08-06-2011, 07:19 AM
Hitaslice's Avatar
Trader Rating: 32 (100%+)
Default Spraying LM
When you guys spray your liquid mask do you leave the left over in the container or clean it out like your airbrush? I only do about 2-3 bodies a week so I don't want to use it if I am only doing one body.
Ed
Hitaslice is offline
Old 08-06-2011, 05:21 PM
Bfutura15's Avatar
Ed
Just pour it back into the container. Do not leave it in the brush. It will dry out and then you will have problems.
Old 08-06-2011, 05:34 PM
I only use the spray gun when I have numerous bodies to mask, dump the excess back into the container and run some warm water through your gun, and that should be enough.
lifeguy is offline
Old 08-08-2011, 09:14 PM
chitownpnut's Avatar
Great thread guys! I just made the switch from masking tape and I have done 3 bodies with the liquid mask brushed in 3 heavy coats, WOW, what a difference. I have a small hlvp touch-up gun in gonna try to shoot the mask through, heres the ?...What mask is everybody using and where is the cheapest place to get it? Thanks, Paul
chitownpnut is offline
