Rookie airbrush question
OK I painted my first body in years with an airbrush today and had a few issues... First and foremost I had what I can best describe as spider-webs everywhere... By spider-webs I mean hair like stings of paint that seemed to be floating off of the edges of the body, the tape and pretty much everywhere... They got so bad that I had to literally wipe them off after the paint dried... What am I doing wrong to cause this?
The second problem I had came when I pulled the mask off... The mask came off easily enough but the paint didn't separate cleanly and made my edges a little raged... it was as if the paint stretched and "fell" on the unpainted portion causing an line that wasn't smooth... Why is this happening?
Thanks, for the advise.
Shane
Shane
What kind of paint were you using, and how old was it? As for the 2nd problem, it sounds like the paint wasn't dried enough and hadn't properly adhered to the body. I find it helps to sometimes retrace over your masking lines with a knife before pulling the mask off, especially after heavy coats.
I'm guessing that your using pactra?? This is a common issue from what I've read. If you do a search you should find some threads on this, but from what I remember its a problem with too much PSI and/or not thinned enough.
1. Too much air pressure, the paint is drying before it hits the body causing the cotton candy/spider web effect. Try thinning it down some more and lower the pressure.
2. The mask was probably due to too thick of coats. You need to do light coats and build up the paint. Usually this happens when the paint is above the mask.
Not sure about the first question but the second is most likely spraying the paint too thick or not having a new (sharp) xacto knife while cutting it out. I always use a new blade for every body to get the cleannest cuts. also when you spray the paint too thick it almost bonds to the mask and then rips along the lines. Hope this helps a bit.
