Painter's Chat
#2086
I
#2087
What paint are you using? It sound's like you're trying to cover with fewer coats. If you are using something like faskolor or createx try reducing the paint. I use AutoAir flash reducer 4011. Stuff is fantastic. Also, how do you prep the body? Hot soapy water with a clean rag or sponge then buff it with a scotch brite to give something for the paint to hold onto then hot soapy water again. Something else that may cause that is humidity. The paint may be dry to the touch but is not cured enough. When I use water base I always build up color and cook it with a space heater between coats. Hope that helps.
I use createx. I scuff with red automotive scotch brite then wash with hot soapy water. I've never really thineed my paint. It's hard to measure out and I feel like coverage is worse when I've tried and I'll get bleed through. As far as curing fully that might be it. I usually use a space heater but sense it's been summer I don't use it. And I do a seal coat with rustolum paint and primer. I'll try scuffing more and using the space heater again. What ratio do you thin? And how do you measure it? I know some mix it right in the air brush. Also how many coats?
#2088
#2089
As far as how many coats, it just depends on how deep you want the color. Just remember, you're layering paint droplets and you have to layer those droplets to get coverage. When you put on a heavier coat the water in the paint doesn't have a chance to "vape" off and you end up with a top layer film or skin. Kind of like pudding when you put it in the fridge and don't put plastic wrap on the surface. Takes forever to dry.
Just be patient. Don't rush it. If you only get a little done on a particular day because you need to put on a few light coats and dry between then so be it. You and your customer will be happier about it.
Hope my ramblings make sense.
#2091
#2093
I've had issues with createx. Just exactly what you are mentioning which is why I quit using it. It's almost like Latex paint. Others use it and won't use anything else. With the AutoAir 4011 flash reducer you only need a few drops in a cup. Just mix it right in the cup. Its easier to control that way. If you have a thicker paint you'll need a little more. Over time you'll figure it out. Something else the reducer does is stop dry tip on the brush.
No I appreciate all the feedback. It helps a lot. I'm probably trying to rush it along to much. I think I need to put my liquid mask on thicker and use reducer and more light coats and be patient and give it time to cure. The pudding analogy is perfect. What brand do you spray? I'm assuming auto air? I've used some of that and really like the way it sprays but createx has way more colors and is easy to get my hands on being stocked by hobby lobby. I've noticed faskolor has fallen off every where and spaz stix as well.
#2094
I actually use a lot of SpazStix. It's my go to paint. I also have a grundle of Faskolor but don't use it that much. I've learned to work with the Faskolor and reduce it so it sprays well.
I love Autoair paints. It's actually a water base automotive paint and they do have lots of colors and have just come out with some new water based candies that are amazing. Check out coastairbrush.com. They sell it. You can also buy it at your local auto body supply store. Another good thing is that they have 4 oz. bottles. I get white and black in those sizes.
How many costs of the mask do you put down? I usually do 3-4 heavy coats.
#2095
#2096
The AutoAir you can get at coastairbrush.com. Go check out the site. They have all kinds of stuff. The spaz I buy directly from their website spazstix.com. I should correct myself on the mask. It's 3-4 medium coats. It's kinda weird but the sound of the body tells me when I've got enough. When you pick up the body and toss it in one hand and it doesn't make that hollow sound you're probably just right. Weird I know.
#2097
Do you use a hair drier in between coats with the liquid mask?
#2099
Do not use spaztix paint!!! This is the worst paint for lexan. It will not stick no matter what you do. It is a known problem with it hence the reason you dont hear any of the big name painters using it. I've been painting for over 25+ yrs. It will not stick. After few hits it peels off in sheets no matter what you do!! I scuff all my bodies with gray 3m scotch bright. Red is too coarse. Wash with dawn dish soap. All I use is auto air, wicked, and createx. It is the exact same stuff as faskolor!!!. You actually use any acrylic craft paint. It will just need thinned. Regular Windex is one of the best things to use to thin it. It will stick and you will have no issues.
