How to remove paint
#16
Now, I would never ever try to do this with a small 1/10th scale body. It is not worth the time and money for sure. Just the paper towel and the brake fluid is already half the price of the body. In my case, one I just wanted to see if it can be done and two the body for the 1/5th scale car is expensive like $200.
So to make the long story short right now I got a ton of brake fluid all over the body and waiting to see what happens. For sure I will post the results, a good looking body on the car or in the trash.
Thanks Tiko
#17
I've tried Dot 4, graffiti remover, lemon based products you name it. The shell will never look the same. ever. Cloudy, remnants of original paint etc.
#18
#21
last week DOT4 on a bulldog body painted with spaz stix and faskolor works fine for me. only where mirror chrome was used, it looks a little cloudy...
#22
4 days are you serious? i used it tonight DOT 4. it took only a few hours the longer you let it soak the softer the paint gets and falls off. use a soft brisle tooth brush it makes it easy to scrub off with no scratch marks. my slash body is paint free again for another paint job.
