Off-the-Hwal Custom Painted R/C Shells
#196
I know R/C Lidz recommends that in his write up HERE
...but even with chrome I cut the entire design out no matter what, doing chrome first if needs be. Just try to not lay the paint down so much that it bleeds.
It's not a "right" way...I just prefer cutting the whole thing out first.
#197
I definitely do it the way in your drawing. As you can see in that step-by-step I use a normal sharpee marker...When I go to cut the design I tend to follow the outer most part of the markings....erase it and eye the parallel lines.
Look at the drawing below...That's generally how I do it. Hope that helps.
thanks for your detailled answer
#198
This one was for me. I raced for the first time in well over 15 years...Couldn't get it right racing; bashing walls and breaking the servo. Stepped on some poor dudes car when corner marshaling after I got another car out of a corner. I think I'll stick to painting.
All other orders are on rush. Sorry for all delays.
#199
#201
Sick work as usual
#204
#205
R/C Tech Elite Member
#209
Do you have a closer pice of the headlights and grille? I like the looks. Might have to borrow the headlights,
Very clean
Very clean
