Ever ran jr9100t with no lipo reg?
Has anybody tried this? What happened?..........
Well, After reading all these posts I tried it and had no problems. I ran the car for about 20 to 30 minutes and everything worked fine. |
Originally Posted by addicted427
(Post 8350841)
Originally Posted by token
(Post 8350943)
UP IN SMOKE.............
dint want to start a hole new thread.....so ill ask here, running the HV servos, do they drain your receiver pack faster than running reagular servos with a regulator?
I ran the 9100t's for years on straight lipo without any issues.
The HV9100's dont drain significantly more than the regular 9100's. |
I tried it and it smoked after 2 club races, I noticed that both servos over heated and only one failed.:cry: dont try it.
I run Life packs now but they really dont last charged as much as a lipo does. |
Originally Posted by infanterene
(Post 8351055)
Originally Posted by 071crazy
(Post 8351752)
They cant draw significantly more if they only last a few tanks. :ha:
I ran 9100's on Lipos for over a year unregulated. No problems for me.
The 9100 series servos need a 6v regulator, the 7v regulator will cook the servos. Ive had zero issue for 3 years now with the 6v regulator lipo combo.
A simple 2000 mAh pack will last all day, three rounds of Qualifying and a 20 min main, thats for either the HV or 9100 series servos. |
I cooked 3 of them with in mins running Losi 7.4v Lipo and DX3R radio. No Regulator.
Not a good thing to do, unless you have $100 servos to burn up. Just saying. |
(Post 8354291)
Not really sure what that means.
I must be very lucky. First I run the servos for years on straight lipo with no problems, then I run garbage servos again without issues. Either I should play the lotto or I know how to set my endpoints.
(Post 8357764)
