Compessor
Compessor
I have a 2 gallon air compressor where I can set the pressure, is it to strong to use with an airbush? What would i need to set it to
Re: Compessor
If so, yes you would want to set your pressure to 30~40psi. It all depends on what type of paints and airbrush you are using.
Is it like this one..............
Yes, it has a regulator. It is a Cambell Hausfield not that model, it is the yellow one that has the two one gallon tanks. I have a pasche and a badger airbush. Thanks for your help!!
I will be painting lexan bodies with Pactra paints.
Do you have two guages on your compressor (like the one above)? There should be a knob on one and that functions as the regulator. You turn it one way and the pressure on the gauge goes up, you turn it the other way and the pressure goes down. This controls the pressure going through the line.
BTW, the other gauge lets you know how much pressure is built up in the tank.
I don't have any experience with that model compressor you have but the one Punisher pictured is the one I just threw out. If you aren't planning on doing a lot of bodies it will work just fine, but if your going to be doing a lot plan on getting another compressor pretty soon. It only took 6 months before mine wouldn't hold any pressure. It seems they cut costs, and reliability, by using a rubber piston ring in the compressor pump. So when you do a bunch of bodies and the compressor is frequently running the rubber piston ring gets hot, expands, and then desinigrates. I took everything apart on mine and found a piston sleeve full of fine black powder. I tought it would be an easy fix, but of course they won't sell you just the o-ring. But they would cut me a good deal for a new compressor motor and pump ($50). So I just broke down and bought a new compressor.
what kind of cumpressor should i get? How much will it cost?
I would have to agree with Bad Andy on this compressor (picture above). I went through two of them in the two years of airbrushing!!! You will have to pay above $100 to get a good reliable air compressor. Like some of yall my air compressor dose double duty for me like blowing off my R/C cars and other house hold duties. If you are planning on using your compressor for more then airbrushing a better quality compressor is better for ya!!
