Another problem - paint peeling
I have this problem that has bugged me for some time,
it's almost as if the layers of paint won't stick to each other.
When I peel masks off, the layers of paint come with it, minus the first (thin) layer of paint.
I use tamiya ps paints and faskolor paints...
I dry with a hairdryer between coats and leave for 24 hours before peeling masks.
only thing I can think of is that the tamiya ps paint is not compatible with the faskolor paints. but i've got no idea.
maybe put down a thicker first coat, or not let the paint 100% dry between coats?
Try washing the rest of the paint off it sounds like it wont be too hard to get off. After that wash the body with soap and water use some scotchbrite pad.
Then when you paint it make sure you use paint specifically made for lexan or polycarbonate. Use thin coats while painting also.
