Trouble spraying Parma Fascolor.
#16
Originally Posted by doorman
(Quote Barry W.)
Last time I used ISO alchohol on this paint it curdled, like old milk. What did I do wrong?
Barry,
The only time I have ever run into this problem, is when you use a ISO rating above 70% Alchohol.
Try not to use 90% or anything like that.
Its just too strong!
Doorman
Barry,
Doorman
OIC.. Thanks for the reply, Doorman. I have this problem with faskolor mixing with alchohol too. It turn my paint into a very 'gummy' substances; which is unsparyable.
But the same alchohol works fine with the tamiya paint.
May I ask; when you say "ISO rating", what does it mean??? Some kinda international standard???
The alchohol I'm using does not meantion any of these. The label reads
" I.P.A Solvent" - can be dilluted with water. Am I using the right stuff??
Thanks for reading.
#18
another thing, don't mix the alcohol straight with the paint. Mix it 1:1 with windex or water.
I have 2 paint bottles within reach with the following.
1) 1:1 mix of 70% isopropyl alcohol/water (I use this to thin fastint)(yes, I reduce fastint)
2) 1:1 mix of windex/water (I use this to reduce everything else parma)
hope this helps
hope this helps
#19
hope this helps
hope this helps
Thanks for the tips XAC. I'll try the 50-50 method. Hopefully I can find the 70% isopropyl alcohol. I love to try windex, this can't be wrong with so many painters recommend it. But problem is, I coundn't find this brand here. There's another maker call "magic cleaner" - same blue stuff, hopefully both are the same....
Cheers.
#20
FAskolor
50 PSI???
Wayyy too much PSI.. I shoot mostly at around 15-18PSI and I have no problem with my faskolor.
WINDEX is the only way to go IMO... I do around 60/40 paint to windex works for me. I have a few empty containers so I empty half paint then top with enough windex shake and paint.... I do a little more for certain colors, but in general 60/40. And definately no more than 25PSI... Hope this helps..
Oh yeah.. I use an Iwata Revolution HP-CR with a .5mm tip. Best bang for your buck...
#22
hope this helps
hope this helps
#23
Well the windex worked along with a new compressor! Now how do you fuel proof the faskolor painted bodys for 1/8 gas
#24
#25
Trader Rating: 32 (100%+)
#26
#27
Airbrush
Big Red,
The key to faskolor is that not all colors, and bottles of colors are the same unfortunately you basically have to start out with feel.... so what I do is I attempt to spray it stock out of the bottle by putting a few drops in my cup and set out on a piece of scrap lexan. I try to do thin lines, and I test big spray patterns, and see what the paint does... does it clump the tip maybe it won't come out at all. Then I know more or less what it will take to get it to work well. Sometime it shoots great as is or only needs 10% windex, sometimes its ass and needs 40-50%. That is my biggest tip... take each bottle as its own type and test before use, only takes a couple minutes, but the next time you go use it.. it will be perfect.. RIGHT! LOL
As for your Airbrush.... there are alot of guys out there that will praise paasche but you have to go IWATA all the way.. 70-80% of painters I believe use then and since I switched to a Iwata Revolution HP-CR from my badger its been beautiful... never a problem, easy maintenance, and well priced. You can get them off ebay for around 70US and it has .5mm tip and you will not have a problem, spraying anything..... ENJOY!!
#28
I have a big sheet of plexi i can prctice on. The 60/40 was more like water droplets when it came out. One more qustion, how hard is it to make the adjusment from the single action airbrush to a dual action?
#29
as for airbrushes...
It's like going from a bugle to a trumpet (for those musically inclined). Or a cheap AM radio to an m11. or a radio shack humvee to an associate b4.
Basically, if you know what you're doing with a single action you'll immediately notice the difference and have more control and paint MUCH better. If you have no clue whatsoever, you'll notice a difference in control and continue to suck (& learn). It's not a hard switch either way, it's just more control and if you know how to use it, you'll paint better.
#30
Airbrush
Actually , switching to a dual action is not that bad, as I started back into painting just under a year ago. It's push down for air flow and pull back for paint. It's like night and day compared to a single action. This will give you the ability to alot more detailed work, and save paint. If you have a hard time.... just post your problems... I'm sure one of us will be able to help, but I'm sure it will be ok..
