Like Tree457Likes
Your Custom Paintjobs
Old 01-14-2007, 10:37 AM
  #10741
Skiddins's Avatar
Originally Posted by 2-Bad
How do you paint those small square checks (like carbon fibre).... anyone?
This thread page 10
Skiddins
Skiddins is offline
Old 01-14-2007, 11:29 AM
  #10742
Victor A's Avatar
Originally Posted by audiaudi
Haven't check for quite a while as I m not in my hometown...
I actually draw on the shell every time when I have to paint a new shell, it is a bit dump but I like to make some minor changes on each shell. This one is a copy from the brain speed graphix from Japan, and this scheme is for the Kyosho team driver Atachi, so you better check the Brain Speed web for more detail of this scheme. Besides, I don't use liquid mask as I think that is a bit too messy, I only use masking tape, even it will be more expansive.
That's my bodie . It looks even better than on those pictures. I will post a better picture soon. It is now mounted on a Corally RDX ''2005/2006 Prototype'' .
Greetings Victor
Victor A is offline
Old 01-15-2007, 09:17 AM
  #10743
Ken McKinney's Avatar
Here's some shells that i sent to Novak.
Attached Thumbnails Your Custom Paintjobs-rc-bodies-003.jpg   Your Custom Paintjobs-rc-bodies-004.jpg   Your Custom Paintjobs-rc-bodies-006.jpg   Your Custom Paintjobs-rc-bodies-007.jpg
Ken McKinney is offline
Old 01-15-2007, 09:19 AM
  #10744
Here's the there one.
Attached Thumbnails Your Custom Paintjobs-rc-bodies-056.jpg   Your Custom Paintjobs-rc-bodies-061.jpg   Your Custom Paintjobs-rc-bodies-064.jpg
Old 01-16-2007, 12:23 PM
  #10745
monstergecko's Avatar
Default Replica paint job!
here's a replica body I painted up. I made the mask on a vynil cutter and will post the 5 masks I have left for sale in the for sale forum if any one is insterested! Cheers, MG
If you want to see the original go to:
Bitty Design
monstergecko is offline
Old 01-17-2007, 12:04 AM
  #10746
RAL
RAL's Avatar
Trader Rating: 67 (100%+)
Default 12th Scale PSE Speed 8
New 12r...the lime green has a flake but its not showing in this light.
RAL is offline
Old 01-17-2007, 05:25 AM
  #10747
SlamMan's Avatar
Nice job! Could you explain the process of using the vinyl masks a little more? Did you lay them all down on top of each other? Did you wet apply the vinyl? How did you do the pin stripe? Thanks!
SlamMan is offline
Old 01-17-2007, 05:36 AM
  #10748
Sport Injection's Avatar
wow... I love this thread.
Im sick of doing rattle jobs.... what entry level air-brush do you guys reccomend? Is Paasche, Iwata any good?.... dual stage? ebay time.. OR maybe look on here? Thanks for any info ( edit: I just found a huge thread on this.... search first next time )
Sport Injection is offline
Old 01-17-2007, 05:48 AM
  #10749
litsluv's Avatar
Here's a couple of my latest.
The Altezza is done with Spazstik Chameleon paint. The Mini is a custom mixed British Racing Green.
litsluv is offline
Old 01-17-2007, 08:28 AM
  #10750
Default SlamMan
Thanks! I kinda did this on my own so any of you pro painters can set me straight.
I designed the masks in illustrator with all the bits that you see, stripe, background and all. I cut them out using a vinyl cutter. Using transfer tape, I transfer the cut vinyl to the un-painted body (kinda like applying window tint) soapy water spritz. I finish off the body by taping it off with masking tape. Then I simply peel out the part I want to paint, paint it, peel out the next part I want to paint. The next time I start to paint a new body I will take picts to doc the process. This way it is easy for me to paint 4-5 bodies the almost the same. Hope this helps for now - time to go to work.
Cheers,
MG
Old 01-17-2007, 12:34 PM
  #10751
TRFTIM's Avatar
Default Another shell passes mybrush
Heres another
Faspearl White
Custom pearl blue
Fluro yellow
and Orange
TRFTIM is offline
Old 01-17-2007, 01:02 PM
  #10752
Hey MG....
If im gonna use plotted vinyl to mask some letters....... will I always have to cut around the letters after spraying before peeling? In the past I had paint peel ... any tips???
Old 01-17-2007, 01:37 PM
  #10753
Serandin's Avatar
Default too thick
Originally Posted by Sport Injection
Hey MG....
Sounds like you're spraying your paint too thickly. Do really light coats and let them dry completely (a hair dryer helps with this). The only paint I ever have problems like that with is my pearl black. Everything else works fine as long as the coats are light.
Serandin is offline
Old 01-17-2007, 03:16 PM
  #10754
My thoughts exactly. Light thin coats, Allow dry completely before you peel, you may also try very lightly scuffing the inside of the body with scotch brite before you paint, that seems to help too.
Cheers,
MG
Old 01-17-2007, 06:02 PM
  #10755
Mr. McGoo's Avatar
Trader Rating: 23 (100%+)
here is Papi Lopez's scheme for Snowbirds -
edit - added some better pics....
Attached Thumbnails Your Custom Paintjobs-papi-lopez-005.jpg   Your Custom Paintjobs-papi-lopez-009.jpg   Your Custom Paintjobs-papi-lopez-010.jpg
Mr. McGoo is offline
