Your Custom Paintjobs
#7921
Amazing paint work guys, very nice jobs. I just wanted to find out how to get the outline around the edge of the windows. Exactly how do you guys do it? Would that be the last step in painting? The way I've been doing it is to paint the entire body with the windows fully masked, then when I'm done with everything else, try to mimick the windows edge about 3mm in to the window mask with a sharp exacto, then peel off the edge of the window to paint it. It never turns out nicely or evenly since it's almost impossible to follow the edge perfectly. Thanks guys.
#7923
Originally Posted by burgboyz
What I normally do is take a popsicle stick and attach two sharp #11 blades onto it and your good to go.
shaggy
shaggy
#7924
How do u guys do it>? suprizing
#7926
last nights work...
#7929
Originally Posted by dodgeguy
Here are a couple for a recent customer
#7930
I have masked windows 2 ways over the years. The first way I did it was to paint the body and pull the window mask off. Then using some vinyl I cut into 1/8 strips about 4 inches long. I would mask off how wide I wanted the window trim. Then I would mask off the rest of the window with larger peices. Then spray. It works but takes more time than how I do it now. I just use the mask I used supplied by the body maker and with a sharp blade and a steady hand, I just cut out the trim. You need to keep the blade moving or you will end up with wavy lines. This method takes some practice. But I get really good and sharp windows either way. Take your time and practice.
#7931
#7933
heres my second time with an airbrush...
#7935
wow, lots of ppl painting this weekend! i will have another later tonight or tomorrow.
